dose anyone no if the 200cc kit is any good
How much would that set you back though, money wise?Com'on think of it, our standard BHP is around 12 at the wheel...
With a 182 malossi kit/200 kit (no malossi tho'), PCV, Aftermarket exhaust, aftermarket air filter and some other things our bikes have a possibility to pass 25-27 BHP at the wheel (I think)
That's over twice the power = plenty of more fun!... It won't change top speed very much to, maybe 10-12mph extra... But the torque, much faster from what I've seen!
Haven't read threads but how much does this cost?mozz said:can you in any way justify spending that money on a r125
You're looking minimum ÂŁ650 if you want it all done properly and all the correct gear and set upNickRonnieBiggs said:Haven't read threads but how much does this cost?
Jheeeeze! Then aftermarket exhaust on top?jayr6 said:You're looking minimum ÂŁ650 if you want it all done properly and all the correct gear and set up
That 650 is just for the malossi and pcv without fitting then you have filter, power cam, then exhaustNickRonnieBiggs said:Jheeeeze! Then aftermarket exhaust on top?
R182 is mad fun I use to leave the stock r125 for dead pretty much any other 125Jed said:Waste of time and money. Better to do your test and get a 600.
Not to mention you won't be able to sell it back on as a 125 unless you revert it all back. So in that sense, you're seriously cutting down your target market. Only people who are willing to have a fiddled with R182 and people who would, for some reason, prefer one over a bigger bike will actually buy it.
It will also void any warranty you have on it, and could cause some pretty bad engine wear in a short amount of time.
Do your test, save your money.
Didn't have a problem runs fine wouldn't worry about warrantyIrish Al said:Bikerboy never had a problem so this is not true. Also the warranty that yamaha supply isn't worth the paper it's printed on. If they can they will get out of replacing anything under warranty.
Damage what Naa man I redline the crap out my bike ride it hard everyday full throttle every where when I take off the 182 kit the ring and seals piston still look newJed said:It could cause damage to the piston and I'm sure the rings would need replacing more often.
Definitely not worth the money for a bit more acceleration and maybe 10mph added on to the top end.
Exactly, loads of people say loads of things without actually really knowing or owning one of these kits. Makes me laugh how they all seem to be experts because they're going on other peoples opinions.Damage what Naa man I redline the crap out my bike ride it hard everyday full throttle every where when I take off the 182 kit the ring and seals piston still look new
Did theyTesan said:West London yamaha sorted me out. But yeah you have to basically convince them it's a manufacturing fault
You on about bush Yamaha them guys cool no problem with themTesan said:Yeah tbh it weren't my fault but they seemed cool with me, Rik especially
