21 - 40 of 47 Posts
Yeah but why wrap it around the spark plug? I dont see the reason haha
Cause the spark plug ignites the same amount of times, IE electricity gets sent through that wire...
its not for stupid people if you cant get it to work without it ;)
If you can't get it to work without it you ARE stupid ;)
(Joking, so noone gets offended)
i would assume that the high voltage travelling to the spark plug induces a current (from the electro-magnetic waves produced by the signall travelling to the spark plug) into that of the rps signal wire.. more times wrapped round the spark plug wire = higher current induced = better signal for the tacho. sorry if i've used a load of techy words there :L tried to make it simpleish for if someone doesnt understand electronics too much but not sure how well i did :L
You did well ;)
If you were going to put it on the spark, you'd probably want to do it before the coils wouldn't you?
The spark plug has quite an unstable electrical signal (being a spark), whereas the initiating current would be a more stable pulse.
I assume that before the coil would be a very small signal, it doesnt need a stable signal all it needs is the big voltage spike, the rpm is calculated by counting the amount of these spikes..... I think :L
It won't need a large voltage to run. I've just been reading the KOSO manual and it recommends pre-coil if you can't find the original tach wire, the spark splug just isn't a good reliable source as the actual signal wires on other parts of the bike.
Any progress yet Dimitri?
Fair enough xD I was just educated guessing at how it may wrong never said I knew I was right lol
No it's good logic, as long as the spark plug was a single high-powered pulse, but sadly it's not; it's got some big interference in it, due to the way the spark is actually generated
Discussion starter · #39 ·
Nope, still no progress..
When wrapped around the spark cable, the tachometer doesn't work well..
But I've also seen that the engine management light is on because I disconnected the original speedometer :p
Maybe that why I can't find any wire that gives the rpm?
I will take a look at it next week, because I've already put everything back on.
I also find it weird that when connected to the negative side of the coil, I don't get an rpm signal...
I've measured it and it gives a raising voltage as soon as you rev (starting from aprox. 12v)
21 - 40 of 47 Posts
