how much is loads? a little oil in there is normal since there's a hole where the oil can get through (arrowed in red, flywheel sits where the blue circle is).
As you can see most of the area on the other side of that hole (the sump) is lower, so normally oil wouldn't really make it up there or if splashed up there, would drip back down into the sump.
Perhaps you leaned the bike over to the left before opening it, or perhaps it's a bit overfilled with oil?
