so I've just had a reply from tuneboss who I got in touch with months ago, and was hoping to become a uk distributor for.
This is an ECU which should work wiht Gen1 and Gen2 bikes (2014-2018) and allows both fuel and ingition timing adjustment. The gen2 version also has a sort of "auto tune" based on the narrwoband o2 sensor.
Apparently legend (of legend's garage on youtube) managed to hit 95mph on his gen2 with basically stock bike + TB ecu. I can't find the video for it now but will post it if i find it.
Rather than increasing the cylinder capacity, the tuneboss lets you extend the RPM range which is how you get the extra top end.
Now tbh extending the RPM and messing with ignition timing are both things which will let you kill your engine real quick if done wrong, so imho it should be set up on a dyno (my local place chrges about £200 for this). Though the gen2 version has a sort of auto-tune based off the narrowband o2 sensor. It's not perfect but might let you skip the dyno and still get a decent result.
Is this something there's any interest in if I can get hold of them? Idk if they're still makign them, or of there's any old stock or what, or what the cost is but I'm expecting to be abourt £300-350 after shipping, brexsh!t duty and whatnot. Even if they exist, quantities will prob be extremely limited as I'll probably have to buy them up front and I'm not made of money.
I don't think they've carried on doing the R+D for the 2019+ version as they don't have the R125 in malaysia, but if you have a 2019+ and can take a photo of the ECU plug I can ask and perhaps there's a version which is compatible.
If you're on an L-plate here in the uk then you're only allowed up to 125cc, so a big bore kit is illegal right out of the box, but a replacement ECU which extends the RPM range would kinda give you the same result but much closer to legal.
I've got a (gen1) bike booked in for some work in the next couple of weeks which is wanting one of these ECUs so if these ECUs come to pass, then I should know more once I've done that bike. I think it's getting dynod too so we might have some solid numbers then.
