1 - 19 of 19 Posts
I was thinking about getting some new LED's capable of changing colours and have a switch to change modes/colours
bikerboy, Benji maybe you could help? :D :D :D
i am not sure never open one up yet are try this before but if i have a 2nd hand unit i could give it a go
Apparently you should have a thing like the sidelights underneath that you can pull out, but never gave it a go
i have found out that it takes 'SMT' led's
This has been done before!
You open it up, de-solder the exisisting LEDs, and then solder new ones in I believe.
You are spot on with the SMTs.
Why would you want to change it though?
It's RED for a reason!!!!
Any other colour is just annoyingly distracting.
Troy has a blue backlit screen. It annoys ME when I ride with him!
Discussion Starter · #8 ·
simply for looks, i'd like to be able to switch colours (dunno if that's possible) so i could have red whilst riding and other colours for showing off, no idea how to solder btw!
You'd have a right challenge to do it then Gweglez. It'd need some Multicolour LEDs, and a bit more circuit adding to the board, along with a switch you'd have to try and route somwhere and find space for wires, and try and find a place to solder a switch onto the existing board!
You could probably get it made by a company and move the old parts over, but I doubt it's worth it really.
http://www.sparkfun.com/products/7844
Discussion Starter · #11 ·
sounds more hassle then it's worth then, still would've been nice. Red will do fine...for now :p
this was done by Kev. i believe he was doing it for people. head over to r125.co.uk and search through the how-to guides.
If you find me a new soldering iron, I will do it for you!
My only soldering iron at the moment has a head about 2cm wide!
I need a precision one!
i got one you can use
1 - 19 of 19 Posts
