21 - 31 of 31 Posts
I just changed both my headlights to H7 when I took out the old ones one had a little extra bulb bit down the bottom. Can I use H7 in both high And low beam?
Thanks
Thanks
in the R125, the bulbs are H7's in both sides, the one side is for high beam and the other is for low beam as I'm sure you know, as for this extra bit I have no idea, get a picture up if possible and will try to get back to you :)
Thanks if I take them out again I will. I changed them to H7 55w just ones off eBay when I turned on the headlights tho there was a burning smell so I quickly changed them back.
that says it all mate haha, cheap ones of ebay run so hot its unreal, I have done the same but never again, will buy a branded set if I ever need to again :) mine are 55w H7's standard in my R125 but I've put HIDs in mine, look better and way much more light on the road just have to make sure its not too bright for other people on the road haha
Yeh I would love hids. I just worry that the cords and stuff might look messy or that I will stuff up the installation (I'm a bit of a perfectionist ) lol
Would you recommend the Phillips diamond vision bulbs if I don't get hids?
haha, I know you have to cut up the high beam bulb holder to get the HID's to fit so I'm sure that would put you off doing it lol, and I haven't used those bulbs so cannot recommend them, but I'm sure they would be good as they are from a good company.
I know Osram are top quality makers of bulbs so might be worth checking out them and their Night Breaker range ( I think its night breaker haha), but if your bulbs are okay as they are then don't worry until the times comes when you need to change them, I've never had a bulb blow on me so have never had to change them :)
21 - 31 of 31 Posts
