1 - 1 of 1 Posts
Hi, I’ve got an issue with my bike not shifting.. it’s stuck in what i believe to be 2nd gear and it starts and runs just fine until you’re trying to shift gears. If I try to go down like I would shift to 1st the gear ”lever” is just solid in place, it won’t move the slightest bit. However when I go into third the rear wheel just locks up even though the engine is still running with the clutch engaged.
If you or someone you know have had the same problem please let me know so I know what to expect when I split the cases. The right thing to do would probably be to take it to Yamaha and let them have a look I know, simply can’t afford it right now.
All tips are appreciated!!
1 - 1 of 1 Posts
