1 - 17 of 17 Posts
Just recently bought a powerbronze screen but still waiting on my new front nose cone arriving. Was looking at the rubber bits that that i go via pro bolt and notice they are very different from the old ones and was wondering if anyone knew how to fit them properly? I know Benji has used probolt before, maybe a bit of advice?
Should jut fit exactly the same... Can't see that causing any issues, if anything just looks easier to fit :)
Can't you see though that on the original, the bottom lip of the groove is there to stop the screen falling down, but because there is no bottom lip on the pro bolt rubbers then they cannot fit in the same way as the originals?
But there will be a screw going through it, that would stop it from falling out would it not?
Edit: Hmmm, see your point I think...
No more help required :)
Have figured it out on my own, such a simple thing can't see why i never noticed before. :confused:
What happens is that when you tighten up the bolt, the rubber squashes and actually creates the bottom lip on its own, quite smart really.
It wouldn't be like pro bolt to make something that isn't completely genius :p
=] nice. I would have said if you still have issue then to use old ones :)
you get same screen as mine?
Yes got the same screen. Couldn't use the old ones as there are 2 missing from the bottom from when someone attempted to steal the bike.
Damn what Wa**kers!!! I would have smashed there heads in! Get some pictures up cant wait bet it looks lovely
Discussion Starter · #14 ·
Yeah mate. Got a chap at the door at 5am one morning, nearly cried!
Bike will be back on the road soon so i'll be starting a blog and adding picture from before and after all the repair work.
those grooves do hold the screen in place, yes. have you fitted it yet? i don't see how the probolt fittings would work. i also don't see how they'd make any difference if they did fit, those stock grommets are perfectly fine to use.
It took me a while to get my head around it Sam
As I see it, the bolts fit into the probolt grommets and crush the unthreaded centre section upwards as you tighten to create a lip just below the screen.
Genius, really! It's probably what the stock ones look like before any screen is actually fitted...
Discussion Starter · #17 ·
You must have missed my post above, I eventually figured it out.
Very smart indeed but i'm assuming it's the same for the stock ones? Nobody will really know unless the get genuine ones from Yamaha.
1 - 17 of 17 Posts
