1 - 13 of 13 Posts
In the bottom of the front fairing there's two plugs that hold it together at the bottom, just wondered if I have to buy new ones when I take them out or if I can leave it without them???
I left them out as take my panels off often. It seems to stay together.
You dont need to change them. To take them out push in the centre pin it will pop up to release on the inside. Then just pull it out. To reuse push the pointed end of the pin back, slide the plug back through the holes in the fairing then push pin back in.
Reactions: mozz
I've already f***** one of them up and the other one is still in.
My clips broke, so I ended up drilling a hole, and using a cable tie to hold mine together ><
1 - 13 of 13 Posts
