If i switch off my iphone it still comes back on with the right time?Would be too complex, the dash would need to stay powered while the bike's not on!
But even normal phone with battery removed clock is still right. Can't be still running with no battery? i dunno i am prob wrong.The clock stays on, same with all modern phones. Anything that has a clock on can never be absolutely switched off!
Your dash goes completely off I'm sure.
good point i can take my bat out put it back in and time would be correctBut even normal phone with battery removed clock is still right. Can't be still running with no battery? i dunno i am prob wrong.
Maybe the back up thing is more likely as my laptop when i go away and switch it off it has right time when i power up again with no internet.Now here I could be wrong, but I'm guessing some will use a little backup battery or such, and a lot of smartphones will probably auto-correct off 3G or somthing.
Think about chaps, it's a device that receives packets of data, what does it probably do when it registers with a network, yes, it receives the current time, probably encoded as the number of seconds since the epoch, which is normally taken as the number of seconds since the 1st January 1970 at midnight.good point i can take my bat out put it back in and time would be correct
Right so how do you explain my laptop displaying the right time with no internet connection? when powered off and left and then power back on? it would not be hard to put clock on R125 comp as many/most other bikes have it.Think about chaps, it's a device that receives packets of data, what does it probably do when it registers with a network, yes, it receives the current time, probably encoded as the number of seconds since the epoch, which is normally taken as the number of seconds since the 1st January 1970 at midnight.
