1 - 5 of 5 Posts
Hey everyone I’m new here , I don’t normally do forums if I’m honest but looking for a bit of advice. I have a 64 reg wr125r that I brought for doing some green laning only. I drive so not really use it to commute, just to ride to destination really. Anyway I been out on it on some trails and the bike it great apart from going up loose rocks trails! It’s all pretty standard . Just wondering if any one recommended to lower rear tire pressure or change to heavy duty inner tubes and reduce pressure to get a bit more traction. Or any help in this area would be greatly appreciated
afaik runnig lower tyre pressures offroad is pretty standard. Obviously if you're riding to and from the location and dont have a pump with you or are riding a mix of terrains then you dont want to go too low since then you'll be all over the place on the road & rocky sections... so i guess depends on your situation somewhat.. but yes. lower pressures offroad is totally normal + fine :)
If you're getting tyre rollover in corners on tarmac (scary af, feels like the back end just washed out and then "oh no we're back") then you prob need a little more air but you'll likely need to experiment a little to find what's right for you. Just drop a little air out from where you are now (e.g. 5 psi) and see how it feels overall.
Hi thanks for reply , yes we have a pump so that’s not a issue. I do tend to ride to locations though , I will see how I get on. 👌🏻
ah well then if you've got a pump then you should be good :) I seem to remember there were little gas cylinders (co2?) for mountain bikes to do the same job. i wonder if they might be a more convenient option too..i guess depending on how much you like standing there pumping tyres up in motox gear ;)
1 - 5 of 5 Posts
