erm.. can't say I really noticed it, though they're not really much/any wider than my previous clipons, which added about an inch to each side over stock. Also bear in mind I found the OEM clipons a "stretch" whether turning or not because of my back injury, so the slightly more relaxed initial position of the motox bars probably negates any additional reaching during lock.
I suppose I noticed a bit of difference there initially when I fitted those but it was more the "wow she wants to play" feeling from the increased steering control and (at the time) freshly lowered front end (I had to pull the fork tubes thru the head by about 5mm to fit the previous clipons which made for a slightly more aggressive stance). The only downside to that was that it *seemed* harder to reliably steer with no hands at low speeds (likely due to slight rake/trail change idk?). I've not tested that since putting the motox bars on but I'm hoping this will be improved, since slow speed no-hands control is actually pretty important to me.
Currently however, most noticeable is the riding position change...weight seems a bit further back by default (which is what I was hoping to achieve), it feels a bit more laid back in general somehow (also good) and I can almost ride standing up reasonably comfortably so position should be perfect for standup wheelies. I find myself just cruising along at low rpm and looking around more, rather than necessarily flat out banzai mode everywhere (but you can still get down behind the fairing if needed).
It feels a bit different in corners now too with the weight back, having to somewhat re-learn how to corner hard but so far it seems to still be able to do it, it just feels a bit different, but I keep finding myself grinning lots so I guess that's good
I'm actually surprised by how different it feels considering the motox bars are actually no higher than the old clipons...in fact I can see out of the mirrors slightly better now than I could before and they fold up now without hitting the bars, which didn't used to be the case, so they're actually lower than the prev clipons, it's just a slight angle change, so howcomes its feel so different?
I really like how it rides now though - feels right for what I want, poised for naughtiness
