Long story short, got a 2016 yzf r125, had charging problems, battery would be dead after a couple days riding. Charged it after every ride. Now after winter, moto doesnt start. I can push start it and it will run and i can ride it, but it will stall once i stop giving revs. Moto starts fine if the regulator rectifier isnt grounded. I have changed the rectifier regulator twice(once used from a wrecked yzf, and other time a new one) but that doesnt seem to change much. Checked the stator its fine, battery is also no the issue. As soon as the ground wire starts touching the rectifier regulator the lights start flickring a bit and the moto just stalls.
hmm I wonder if you can take particular fuses out from the fusebox and see if it still behaves the same - then maybe use that to try and isolate whichever system is causing a problem?
*Obviously making careful note/photos of which ones go where beforehand.
