1 - 19 of 19 Posts
Combination 1
  • Identify where you would check the engine oil level and tell me how you would check that the engine has sufficient oil. Identify where to check level, i.e. dipstick or sight glass. Explain that level should be between max and min marks. For dipstick explain that you would remove dipstick and wipe clean, return and remove again to check oil level against max/min marks. For sight glass, you would explain that you ensured glass is clean when checking.
  • Show me how you would check that the horn is working on this machine (off road only). Check is carried out by pressing horn button (turn on ignition if necessary).
Combination 2
  • Identify where the brake fluid reservoir is and tell me how you would check that you have a safe level of hydraulic fluid. Identify reservoir, explain that you would check level against high/low markings with the bike level.
  • Show me how you would check that the lights & brake lights and reflectors are clean and working. Operate light switch - if fitted, then check high and low beam, brake lights and indicators (turn on ignition if necessary). Check visually for cleanliness and operation.
Combination 3
  • Tell me how you would check the condition of the chain on this machine. Explain that you would check for chain wear, correct tension and rear wheel alignment. Tension should be adjusted as specified in the machine handbook. Drive chain should be lubricated to ensure that excessive wear does not take place.
  • Show me what checks you would make on the steering movement before using the machine. Show that the handlebars should be free to move smoothly from full left lock to full right lock without any control cables being stretched, trapped or pinched and without any snagging between moving and fixed parts.
Combination 4
  • Tell me how you would check your tyres to ensure that they are correctly inflated, have sufficient tread depth and that their general condition is safe to use on the road. Explain that the correct tyre pressure settings can be found in the owner's manual. Pressures should be checked using a reliable gauge. Tread depth must be at least 1mm deep, forming a continuous band at least ¾ of the breadth of the tread and all the way around. There should be no lumps, bulges or tears.
  • Show me how you would check the operation of the front brake on this machine. Wheel the machine forward and apply the front brake.
Combination 5
Combination 6
  • Show me how you would check the operation of the brakes on this machine. Check for excessive travel on the brake lever and the brake pedal and for unusual play or sponginess. This can be done by pumping the forks up and down.
Combination 7
  • Identify where you would check the engine oil level and tell me how you would check that the engine has sufficient oil. Identify where to check level, i.e. dipstick or sight glass. Explain that level should be between max and min marks. For dipstick remove dipstick and wipe clean, return and remove again to check oil level against max/min marks. For sight glass, ensure glass is clean when checking.
  • Show me how you would check the operation of the engine cut out switch. Operate switch (you don't need the ignition on).
Combination 8
  • Tell me how you would check your tyres to ensure that they are correctly inflated, have sufficient tread depth and that their general condition is safe to use on the road. Correct tyre pressure settings can be found in the owner's manual. Pressures should be checked using a reliable gauge. Tread depth must be at least 1mm deep, forming a continuous band at least ¾ of the breadth of the tread and all the way around. There should be no lumps, bulges or tears.
  • Show me what checks you would make on the steering movement before using the machine. Handlebars should be free to move smoothly from full left lock to full right lock without any control cables being stretched, trapped or pinched and without any snagging between moving and fixed parts.
Combination 9
Combination 10
In addition to one of the above Combination questions the Examiner will ask one or two of the following questions:
Advice you would give a pillion passenger?
  • Make sure they are wearing the correct clothing including an approved safety helmet.
  • Make sure they sit on the bike astride, facing forwards with their feet on the foot pegs at all times.
  • Tell them were to hold. Either to the rider or the grab rail.
  • Don’t fidget about.
  • Lean with the rider and the bike into the corners.
  • Don’t do any arm signals.
  • Don’t look over my shoulder.
What changes would you make to the bike if you were taking a pillion passenger?
  • Increase the tyre pressures according to the manufacturer’s advice (owner’s manual).
  • Adjust the suspension according to the manufacturer’s advice (owner’s manual).
  • Fold the foot pegs down.
  • Adjust the headlights according to the manufacturer’s advice (owner’s manual).
  • Adjust the mirrors up, as the back will squat down.
How is the extra weight on the back going to affect the handling?
  • Acceleration is going to be affecting.
  • On more powerful bike the front could go very light.
  • Deceleration is affected.
  • Stopping distances are going to increase.
  • Cornering is going to be affected.
  • Centre of gravity is higher therefore it is wise to go into corners slower.
  • Front wheel is going to be lighter. Therefore it will feel a little bit vague.
What would affect your balance?
  • Strong winds, and turbulence from high sided vehicles.
  • Drink/Drugs.
  • Poorly maintained machine.
  • Taking additional weight.
  • Poor road surface.
http://lightningpass.com/motorcycle-test-questions
Outside I was only asked one question regarding checking my tyres, he mentioned something about my horn but he obviously forgot to then get me to check it. Then upon return he asked me a couple of questions regarding carrying a pillion.
Most of the questions are just common sense! lol
Remember. 1mm accross constant band 74% of the tyre diameter.
The only one that really needs memorising.
If you DO demonstrate the horn, REMEMBER WHICH SIDE THE HORN IS.
I know of someone who accidently started their bike :p
Reactions: Killachipmunk
A Little bird tells me it could be a guy called "Camereon" =]
Wasn't actually me...
I bossed my Mod 2 :D
Apart from my road positioning... I still can't manage that bit ><
Sorry young man but what does "bossed my mod2" mean?
English
Sorry, I was being flippant.
I meant it as in, "I passed my Mod 2, like a boss".
It's the current internet meme that's going around.
Oh right ok lol I must have missed that... Didn't you do training for mod 2?
Scott Murphy said:
Then you should have "bossed it" as someone showed you what to do to pass, I would have felt foolish if I'd failed after training.
There is always a next day Scott
a woman at the test centre she fail 4 time
Yeah there was a guy there that passed and he said it was his third attempt. As long as a dry day I'll be fine and pass I know what I did wrong for next time.
i was looking at uxbridge they have dates but cash flow slow
1 - 19 of 19 Posts
