Hello everyone,
Hope all of you are well. I'm in need of some help regarding the Malossi big bore 182cc kit. I have the 182cc Big bore and the forcemaster 2 installed. The thing is, when the engine is cold it runs very well and the throttle is very responsive, but when the engine heats up to the normal operating temperature then the throttle doesn't seem to work when I turn it only a tiny bit. To easier explain this - When engine is hot and I turn the throttle 2-3 millimetres the engine wants to stall, but after that it revs up quick. I haven't got a clue what might be wrong. I'm using my stock exhaust and stock air filter and using map 1 on the forcemaster 2 (cylinder + forcemaster Malossi). When I first set up the kit I had to fiddle with the Idle screw on the air intake, because it used to stall after it got warm, idle ran decently but when I revved it after it heated up then it used to stall. After I messed with the iddle screw, Idling and revving seemed to be fine, then I went for a ride and noticed that the engine wants to stall as soon as I want to rev it slighty, idle works fine. Another thing I noticed was that the engine oil after the ride smelled really bad of gasoline, maybe its not getting enough air when its hot? Any suggestions to fix would help a lot. Please help me sort this issue. I doubt the iddle screw could have something to do with this, because the forcemaster injection is based off throttle position not the amount of air coming in. I beg someone to help me out with this.
