1 - 7 of 7 Posts
I once dropped my bike on L/H side, quite stupid how I did it tbh - was stood talking to my friend, thought my sidestand was down, so I was about to get off, and then it came tumbling down, quite embarrasing! haha. No noticeable damage apart from my side fairing scratched a little - didn't know about the shifter until I took it in for my next service, the mechanic had raised it and told me it was low, which I thought yeah, probably true..
Not sure if it's me, but today I was wearing proper Sidi foots for the first time (I usually wear trainers..), and I was having to sit really far forwards to be able to shift up semi-"comfortably" - or is it possible that the shifter would have reverted to how it was before the mechanic changed it (by itself - stupid question probably)?.
TL;DR - Here's a picture, do you think it's low?
Bike is a Honda Varadero 125 (XL125V)
Ah yeah, probably should've put that :p (Edited it in now)
Bike is a Honda Varadero 125, not a common model these days, so I doubt anybody here would have experience with it :(
How easy is it (or should it be) to change the position of the gearshifter?
As for the shifter being damaged, it's not don't worry.
Bike boots are a lot thicker than you think they are, and don't squish.
I had a similar problem with my old bike.
The others are right though, the lever is easy to adjust!
Check your manual on how. Some have a shift rod you can shorten, others are a case of disconnecting and rotating the end slightly
yea thats another thing just keep riding in ur boots!
it might be ur not use to it!
i was like that now i cant ride in trainers!
1 - 7 of 7 Posts
