1 - 13 of 13 Posts
What you think guys?
Tire Wheel Vehicle Automotive lighting Motorcycle
General information
Model:Rieju RS3 125
Year:2011
Category:Sport
Rating:64.9 out of 100. Show full rating and compare with other bikesEngine and transmission
Displacement:125.00 ccm (7.63 cubic inches)
Engine type:Single cylinder, four-stroke
Engine details:Minarellei-Yamaha engine
Bore x stroke:52.0 x 58.6 mm (2.0 x 2.3 inches)Valves per cylinder:4Fuel system:Carburettor. Keihin CVEK 30
Ignition:CDI
Cooling system:Air
Gearbox:5-speed
Transmission type,
final drive:Chain
Exhaust system:Exhaust pipe with aluminium silencer Chassis, suspension, brakes and wheels
Frame type:Triangular double cradle double steel tube
Front suspension:Inverted fork, 40mm.
Rear suspension:Mono-shock shock absorber, adhustable
Front tyre dimensions:100/80-17
Rear tyre dimensions:130/80-17
Front brakes:Single disc
Front brakes diameter:280 mm (11.0 inches)
Rear brakes:Single disc
Rear brakes diameter:220 mm (8.7 inches)Physical measures and capacities
Dry weight:128.0 kg (282.2 pounds)
Seat height:845 mm (33.3 inches) If adjustable, lowest setting.
Overall height:1,100 mm (43.3 inches)
Overall length:1,970 mm (77.6 inches)
Overall width:720 mm (28.3 inches)
Wheelbase:1,330 mm (52.4 inches)
Fuel capacity:12.00 litres (3.17 gallons)
Oil capacity:1.10 litres (0.07 quarts)Other specifications
Starter:Electric
Electrical:12 Volt
Color options:Red, white
Looks okay.... The back is kinda skinny though.
I like the side view more than our bike, (if you exclude the rear).
Front I am undecided on :S
Inverted forks however...
5 speed? Air cooled????
Why don't they ever have 125s set up for test rides dammit! :p
1 - 13 of 13 Posts
