The engine is put back together. But not flooded with fluids yet. Not in the frame.
What interesting did I notice when reassembling the Airsal cylinder? sediment, dust, on the cylinder.
I rubbed the cylinder gently with 1000 sandpaper. Gently two three times
Here's the effect
Here you can see the bottom of the cylinder but there was a similar dust on top. I don't know why it looks like this, but I hope that removing this dust will solve the leakage problem from under the head.
Should I get just the head pins? and separate nuts for screwing the head on?
Here's the effect
Can you write something more about it?Best solution for this would be to have pins instead of bolts to be sure not to damage block against thread pulling but thats whole diferent story![]()
