Not sure if this bread has been done but here they are. To get the code, your orange engine management light will flash. There are to different flashes a long slow flash and a short fast flash. So 3 long flashes followed by 9 long would be code 39.
12 Crankshaft position sensor
No normal signals are received from the crankshaft position sensor.
13 Intake air pressure sensor
(open or short circuit) Intake air pressure sensor: open or short circuit
detected.
14 Intake air pressure sensor
(hose line) Intake air pressure sensor: hose system malfunction
(clogged or detached hose).
15 Throttle position sensor (open or short circuit)
Throttle position sensor: open or short circuit detected.
16 Throttle position sensor Stuck throttle position sensor detected.
21 Coolant temperature sensor
Coolant temperature sensor: open or short circuit detected.
22 Intake air temperature sensor
Intake air temperature sensor: open or short circuit detected.
30 Lean angle sensor (latch up
detected)
The vehicle has overturned.
33 Ignition coil (faulty ignition)
Malfunction detected in the primary wire of ignition coil.
37 ISC valve (stuck fully open) Engine speed is high when the engine is idling
39 Injector (open circuit) Injector: open circuit detected.
41Lean angle sensor (open or short circuit)
Lean angle sensor: open or short circuit detected.
42 Speed sensor
No normal signals are received from the speed sensor.
43 Fuel system voltage (monitoring voltage)
The ECU is unable to monitor the battery voltage (an
open or short circuit in the line to the ECU).
44 Error in writing the amount of CO adjustment on EEPROM
Error is detected while reading or writing on EEPROM
(CO adjustment value).
46 Vehicle system power supply (Monitoring voltage)
Power supply is not normal.
50 ECU internal malfunction (memory check error)
Faulty ECU memory. (When this malfunction is
detected in the ECU, the fault code number might not appear on the meter.)
Hope this helps.
detected.
detected)
42 Speed sensor
Hope this helps.
