Yamaha YZF R125 Forum and Owners Club: Friendly bike community for all. Ecu Reflash | R125 Forum
Ecu Reflash
Discussion in 'Technical / Mechanical Discussion' started by IzNoO, Aug 19, 2014.
  1. IzNoO
    IzNoO Member
    YZF R125
  3. IzNoO
    IzNoO Member
    YZF R125
  4. JamesK
    JamesK Super Member
    Norfolk
    2016 GSXR-750 MotoGP
  5. blackizzz
    blackizzz Super Member
    Stockholm, Sweden
    Real Name:
    Oskar
    R125 -11 Black and Gold
    Other
    I'd look at the FI/diagnostic tool and how that connects, and mimic that, otherwise I'd say that the ports on the bottom right are the ones you're looking for, however, do you have a program capable of accepting the hardware? My guess is no... Which means that it'll be almost impossible!
    Sent from my IPhone
  6. IzNoO
    IzNoO Member
    YZF R125
    same ecu here...
  7. Mysterious Rider
    Mysterious Rider Moderator Staff Member
    HEAVEN
    Real Name:
    GOD
    Yamaha R6 2005 Raven
  8. blackizzz
    Stockholm, Sweden
    Real Name:
    Oskar
    Other
    Look at the video, you have your answer there, you need to buy a converter box or something like that (the black thingy left of the computer)
  9. Billy K
    Billy K Super Member
    Medway, Kent
    Real Name:
    Billy
    YZF-R125
    Chances are the converter is some sort of serial-USB box. I have no idea what type of connection the ECU uses. could be I2C if you are lucky but I doubt it.
  10. Killachipmunk
    Killachipmunk Moderator Staff Member
    Nottingham
    R125
    UK Full Bike (Restricted)
    Way over my head there...
    I know that various people have tried, but as far as I know all of them said the stock ECU is no good, Yamaha never gave out the software to anyone or something. That's as far as I know on the matter.
    Top of this page is someone it's worth looking at, he did a lot of work on this ECU but looks like he reckoned it was secured:
    http://www.yamahar125.com/threads/rev-limiter.3791/page-5
  11. Billy K
    Medway, Kent
    Real Name:
    Billy
    YZF-R125
    I was doing a bit of searching as well. I'm not even sure that there is much logic inside the ECU. As far as I can tell it's mostly SOC logic controllers. So probably only pull a few variables from ROM chips, or something similar.
    If someone wants to send me a spare ECU, I'll let you know lol
  12. Killachipmunk
    Nottingham
    R125
    Wouldn't be surprised... It's a very simple control loop. As far as I know the bike does fuelling based on a very simple open loop: Throttle, Revs, Temperature and Airflow variables. There's no closed loop lambda sensor and no check/adjustments on the exhaust side of things
  13. Billy K
    Medway, Kent
    Real Name:
    Billy
    YZF-R125
    Does it even check temp for fuelling? I thought it was just for "Turn fans on now" haha
  14. Killachipmunk
    Nottingham
    R125
    I think there's an air temperature sensor in the intake tract somewhere. I'd check but I don't have the bike anymore! Will just have to trust my own memory haha.
    I wonder as well if the 2014 model is any more advanced...?
  15. blackizzz
    Stockholm, Sweden
    Real Name:
    Oskar
    Other
    There is an ambient air temperature sensor at the throttle body :)
    Killachipmunk likes this.
  16. Al B
    Al B Well-Known Member
    Luton
    Green YZF R125, Honda RVF400
    The workshop manual says the Yamaha FI programmer plugs into the 'self diagnosis connector' in the yellow/blue wire that connects to the dash. So there's more on that line that just a voltage to blink the fault light. It probably uses a serial signal for the programmer to ECU comms. If the ECU streams data out, so the programmer can see what's happening with sensors etc whilst the engine is running, then it should be feasible to connect the serial line to something like Hyperterminal or Portmon on a PC and watch the bits arrive. It might need some tinkering with baud rates, parity etc to get the settings right but when you hit the sweet spot some pattern of data should become apparent.
    This http://www.strangely.org/emerald/format.html is how someone did it with an aftermarket car ECU. I used the info to make up a software 'dummy ECU' to feed made up data into the programming software and work out what the remaining data channels were. Now I can record the serial stream into the data logger and analyse what's going on.
    To see how to reprogram the ECU you'd need to get hold of the FI programmer, then you could tap into the comms and see what messages go back and forth when the various functions are selected.
    If you could manage to work out the ignition advance mapping then that would pave the way for using aftermarket ECU's. Fully programmable systems cost about the same as the power commander etc fuel fudgers.
  17. Billy K
    Medway, Kent
    Real Name:
    Billy
    YZF-R125
    You could just pass the signal through a microcontroller like an arduino and adjust the baud rate on the fly. Getting information out should be simple, getting usable information out, isn't.
  18. vinasource
    vinasource Member
    Ho Chi Minh City, Vietnam
    Honda CBR150R,Yamaha R125
    Non UK Provisional Bike
  19. Nox_templin
    Nox_templin
    Can't decide, hence own too many bikes
    Non UK Full Bike
    It's possible that the YZF R125 may use the same setup as other Yamaha in which the Yellow/Blue wire is a K-Line communication line ,in which case there are several OBD and ecm flash/hack systems that may be able to interact with the system
    NorthCust likes this.
  20. misiozol
    misiozol Member
    those days is pointless to spend any money on flashing cable as custom ecu that gives lots of more is in range 100-150e
