Firstly here is a link where you can buy the kit from...
Secondly here is a link where you can buy the actual air filter from...
1. APPLY CLEANER
Liberally spray K&N Air Filter Cleaner onto both sides of filter and allow to soak for 10 minutes to loosen the dirt. Do not allow cleaner to dry on air filter.
Hand Hood Gesture Finger Folk instrument
2. RINSE FILTER
Rinse off air filter with cool low-pressure water applied to the clean side out in order to flush the dirt out of the filter. Continue to rinse the filter until all traces of cleaner are gone. It may be necessary to repeat steps 1 and 2.
Sleeve Gesture Rectangle Waist Wood Snow Cable Wire Event Audio equipment
3. DRY FILTER
After rinsing, gently shake off excess water and only allow filter to dry naturally. Do not oil until the filter is completely dry.
4. OIL FILTER
Spray K&N Air Filter Oil evenly along the crown of each pleat holding nozzle about 3" away. Allow oil to wick for approximately 20 minutes. Touch up any light areas on either side of the filter until there is a uniform red color at all areas.
Hand Musical instrument Finger Gesture Wood
Why buy K&N Air Filter? Main reason for me is In the longer run it is cost effective as rather than buying a new filter all the time all you have to do is clean it. BUT i am guessing there are other benefits
well normal air filter is £15. If you bought KN for £45 thats 3 services to get your money back from your link it would be reached less. So tbh it is a good investment if someone racks up miles and a few of us do here. Anyways this is a thread to help people who have the air filter and will be cleaning it anyway.
PS: Thanks for links for cheaper prices
No worry's.
