Guide moved to page 2.
I did not know that!For what its worth, the chain in the OEM kit is a DID O-Ring part.
...things went badly...Take care not to knock the brake caliper of its slider![]()
Yes you can otherwise you would have to take chain off everytime you wanted to take wheel out.Lilday said:Is it possible to take the rear wheel out and re-fit the same chain?
I'm talking like on a push bike...Just pop the chain off the sprocket and drop the wheel out...Then pop the chain back on when you're re-fitting the wheel.
That's what I thought. I asked on another forum and they said you gotta remove the chain and replace split link every time you take the wheel out lol.Yes you can otherwise you would have to take chain off everytime you wanted to take wheel out.
Lol that seems like a lot of work.Lilday said:That's what I thought. I asked on another forum and they said you gotta remove the chain and replace split link every time you take the wheel out lol.
Cheers
Undo the bolts, and twist it a bit, eventually comes out, PITA though.I wondered how you remove the chain guard?
Is it more than one bolt?King Nothing said:Undo the bolts, and twist it a bit, eventually comes out, PITA though.
the teeth becomes shaped more like a wave, if you know what i mean. The chain stretches more. i thinkhow do you tell when u have to replace chain/sprockets?
