be safe out thereAll sorted. ta. Took it for a blast to A537. man that roads at slippery this time of year.
are you mad?!All sorted. ta. Took it for a blast to A537. man that roads a bit slippery this time of year.
Yep with no fuel pressure, due to the pump not running it doesn't build enough fuel pressure, most fuel injected systems, when there is insufficient fuel pressure inhibit the firing of the injectors to allow the fuel pressure to build, hence they won't always bump off. The other problem you can get with bigger bikes, is if they are fitted with a slipper clutch they also won't bump off unless it's a tight slipper.quick note, mine wouldnt bump start wit hardly any juice in battery, not always a dead cert, this confused me so i asked yamaha they said you may struggle with it being fuel injected :S
