1 - 8 of 8 Posts
Hy guys,
I have a question regarding the YZF R125 2021 EU5 model.
It is equipped with a lambda sensor. So my questions is, is it able to adapt my planned mods, BMC replacement air filter, Shark SRC-4 complete exhaust and NGK CPR8EAIX-9 spark plug? Or will I run in problems? Any experience here?
Guitar accessory Bumper Font Automotive exterior Rectangle
Cosmetics Office supplies Tints and shades Auto part Font
Thanks a lot,
Nils
Discussion Starter · #3 · (Edited)
After driving around for now appr. one week I can say everything works fine. I think I have a slightly better response and it revs a little quicker up when the VVA system is active. But it can be also only a subjective feeling as the sound has improved a lot. I´m happy with it, even I run it with the DB-eater.
Tire Wheel Fuel tank Vehicle Plant
Wheel Tire Fuel tank Vehicle Automotive lighting
Hy guys,
View attachment 34028 View attachment 34029
Thanks a lot,
So, we can confirm your exhaust and air filter caused no issues, bike doesn’t run lean and even feels slightly quicker ?
I’ve fitted a for Scorpion exhaust, but have been holding back fitting the K&N for fear it will cause issues on my 2022 R125 60th Anniversary
Discussion Starter · #8 ·
Yes no issues so far. Did now more than 5,000km with this configuaration, There are no flat spots and I think the lambda controller does a good job. Perhaps it is also a little related to the Iridium spark plug as it is able to handle a wider lambda range, espacially in the lean direction. All issues regarding the K&N air filter I found in the net are about the cone-filters, that are directly attached to the throttle housing. But I used a replacement filter in the original closed housing.
If there is a real power add, I can`t swear. Much is coming from the better sound. But I´m 100% sure there is no power loss with this configuration.
Reactions: K9 JSB
1 - 8 of 8 Posts
